Forum: VirtualDJ Skins
Topic: mixstation 4.2
could someone please update this skin for version 8. i use it all the time and its amazing for me.. i have the skin i can send to anyone wanting to do this
Thankyou
geposted Mon 13 Oct 14 @ 5:18 pm
I see there are a lot of different versions and resolutions of this skin.
Which version/res would you like updated?
Bear in mind it will only be the XML code that's modified to function with VDJ 8. The graphics will be the same.
i currently use a resolution of 1366x768
OK...
So which version of the skin would you want modified? From what I can see, there isn't a 1366x768 version available.
i have a resized version from the 4.2 original. i have both xml,s i can send to you
OK....
But what is this version you have? Is it one that's available to download from here (if so, which one?) or is it something unique that you've done yourself?
Throw me a bone here!
i got the original skin from here... https://virtualdj.com/addons/53/MIX_Station.html
i have also uploaded my resized version and the skin here... [external link removed]
its a skin i haven't created.
it was originally designed for version 6.0 of VDJ but i have been using it flawlessly on version 7.4.2.
sorry for the confusion. i don't know a lot about skins and i do appreciate your help.
Thanks. I will adjust where necessary and send it back to you.
Thank you very much indeed ;-)
What's the resolution of your computer screen?
I ask because the graphics in the resized version (I guess you did it yourself) are out of proportion - the jog wheels are not round.
Old skins like this are designed for 4:3 screen ratios (square, not wide) so if you stretch it, it goes out of whack.
I'd been modding the XML code, then when I ran the skin to check things, I noticed. :-(
my resolution is @ 1366 x 768. i kinda got used to the mis-proportion. i don't really look at the wheels as use the video bit quite a lot lol...
i used the skin resizer tool in the tools section to get the skin to that size so guess its my bad
It's making progress. Shouldn't be too long now.
thankyou
Skin updated and delivered yesterday (27/10/14).
Working well and prefect! thankyou. will email you in the next week Groovin ;-)
I'm glad you're happy!
