I would like to have a setting where when my crossfader is all the way to the left, you can hear only the left side, but if i were to move the crossfader only a little to the right, i have full volume on the right side. Same thing if my crossfader was all the way on the right instead. I'd like that setting for scratching, and i dont know how to get that kind of setting. I also use a Numark Mixtrack 2.
geposted Sat 25 Oct 14 @ 11:18 pm
There is a VDJscript called crossfader_curve which can be set to do that.
See https://virtualdj.com/wiki/VDJscript_verbs_v7.html (the one for VDJ 8 is not available yet).
geposted Sun 26 Oct 14 @ 5:43 am
Hi grooving. I need some help with that. i have a dn mc6000 and the crossfader controls on the mixer part of the control only work with 2 decks not 4 decks. However i want to map a button on the control to either select or toggle between the crossfader presets or a knob to select the curve i want. Im very basic with mappings.
geposted Sat 27 Dec 14 @ 6:27 pm
ok i think i am figuring it out
geposted Sat 27 Dec 14 @ 6:34 pm
ok done. the vdjscript worked out fine
geposted Sat 27 Dec 14 @ 7:26 pm
Solution:
crossfader_curve 100%
geposted Mon 30 Mar 15 @ 9:25 am
