Topic: open playlist window per shortcut
Hi
Does anybody know, how to open the little playlist window at the down-right-side with a shortcut?
(VDJ7.4.1)
I´m using a touch screen and the button is sooo small.
(another skin is not the solution cause I have to use my own one)
The answer is not "playlist load" - it´s just about to open the littlie playlist-window.
Thanks for all ideas:
geposted Sun 26 Oct 14 @ 7:50 pm
This is my modified skin (thanks DJDad!) But this doesn´t matter - its VDJ7.4:
And if You go with Your Mouse over this Button (the "playlist"-one) ...
... the playlist window opens.
How can I do this per shortcut (A Key-Mapping)?
Thanks for any help
Any Ideas?
why you don't lock it?
No, unfortunately version 7 doesnt offer any control (actions) to open/close the Playlist window. You should consider upgrading to version 8 and enjoy the tools offered for Touch screens.
Hi jmf28: Cause I need the space in the middle. (Thank You anyway)
Thanks DJDad, I´m waiting for the next big update of VDJ8 to start with it.
For the moment 7.4.1 seems more stable for me.
So Thank You all!
