Forum: Old versions
Topic: Numark orbit remapping i will pay.
jasmupPRO InfinityMember since 2013
I've been trying to remap the orbit for VDJ 8 (the default mapping I dont like) I'm done with trying and I am willing to pay for someone 2 create the mapping for me someone did a mapping that I liked but it was in vdj 7 if you can basically duplicate this layout below and add the ability to use the center as a jog wheels you would be the man would be willing to pay for that mapping. I do not like telling people how much their time is worth so I will let you make the money offer and if I can afford it I will be more than happy to pay.
0-36 deck 1 play_button
0-38 deck 2 play_button
0-37 deck 1 pause_stop
0-39 deck 2 pause_stop
0-40 deck 1 sync
0-41 deck 1 pitch_reset
0-42 deck 2 sync
0-43 deck 2 pitch_reset
0-44 browser_scroll -1
0-48 browser_scroll +1
0-45 deck 1 load
0-46 deck 2 load
0-47 playlist_add
0-49 browser_window
0-50 browser_folder
0-51 browser_enter
0-CC1 deck 1 level
0-CC2 deck 2 level
0-CC3 deck 3 level
0-CC4 deck 4 level
1-48 deck 1 effect "backspin" active
1-50 deck 2 effect "backspin" active
1-49 deck 1 effect "beatbreak" active
1-51 deck 2 effect "beatbreak" active
1-44 deck 1 effect "DFV Flanger" active
1-46 deck 2 effect "DFV Flanger" active
1-45 deck 2 effect "Flanged LoopOut" active
1-47 deck 2 effect "Flanged LoopOut" active
1-40 deck 1 effect "echo" active
1-42 deck 2 effect "echo" active
1-36 deck 1 effect "FlippinDouble" active
1-38 deck 2 effect "FlippinDouble" active
1-37 deck 1 effect "Forward_Reverse" active
1-39 deck 2 effect "Forward_Reverse" active
1-CC1 effect slider +1
1-CC2 effect slider +2
1-CC3 effect slider +3
1-CC4 effect slider +4
2-36 deck 1 loop_in
2-38 deck 2 loop_in
2-37 deck 1 loop_out
2-39 deck 2 loop_out
2-40 deck 1 loop_half
2-41 deck 1 loop_double
2-42 deck 2 loop_half
2-43 deck 2 loop_double
2-CC1 deck 1 gain
2-CC2 deck 1 eq_high
2-CC3 deck 1 eq_mid
2-CC4 deck 1 eq_low
3-CC1 deck 2 gain
3-CC2 deck 2 eq_high
3-CC3 deck 2 eq_mid
3-CC4 deck 2 eq_low
3-36 crossfader 0% while_pressed
3-40 crossfader 50% while_pressed
3-47 crossfader 100% while_pressed
2-48 sampler 1 play_stutter
2-49 sampler 2 play_stutter
2-50 sampler 3 play_stutter
2-51 sampler 4 play_stutter
2-45 seek -4
2-45 seek +4
0-CC10 master_volume
0-CC9 crossfaderal
geposted Tue 28 Oct 14 @ 9:34 am
I will $40 to someone to make this!!!
geposted Wed 29 Oct 14 @ 7:18 am
I can do it (for free of course) but you will have to give me some time... ;)
geposted Wed 29 Oct 14 @ 7:44 am
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO YOUR THE MAN!!!!!! I need it for VDJ 8. For some reason the mapping i had for vdj 7 could not move over to vdj8, then i lost the mapping all together so i could not go back to vdj7
geposted Wed 29 Oct 14 @ 10:46 am
that's because you had mapped the Orbit as a simple Midi, instead of using the version 7 (native) definition. It would have been more easy to convert.
Unless of course the Orbit never got properly detected (for some reason) or never updated to the latest 7.4.1
geposted Wed 29 Oct 14 @ 11:23 am
well i just found out that the old orbit i had was broken and that's why nothing working! thanks VDJ for all the help !
geposted Thu 30 Oct 14 @ 11:21 pm
