Could someone advise me if it's ok to have both VDJ7 & VDJ 8 open at the same time?
I'm doing a gig where the club is using VDJ7 and from a response on the forum a couple of days ago I was advised that all my cue points, anchors ect from VDJ8 are not backwards compatible.
As I am pretty much using a preselected set list for 2 hours so I want to copy over things onto the tracks in VDJ7 manually - unless there is an easier way to do it that is ?
Thanks Guys
Thanks Guys
geposted Fri 31 Oct 14 @ 8:13 pm
So, your not looking to gig like that just make set lists and cue points ahead of time? If that is the case, back up your databases, and try it.
geposted Fri 31 Oct 14 @ 8:33 pm
I can't think of labour saving way sorry it looks like it will have to be manual.
geposted Fri 31 Oct 14 @ 9:44 pm
