Topic: virtual folder backup
So you build a virtual set of playlists over months with hundreds of songs in different files ...then the hard drive crashes ...database and folders gone!!!!
Is there no way to back up the virtual folders? ...we all have the music, karaoke and videos backed up to build a new drive ...but the folders or part of the contents disappear!! ...so you lose the "best tracks at..." list ...and Pete's karaoke set etc
How do i back the multiple virtual folder lists?
Best
Mike
geposted Tue 11 Nov 14 @ 5:07 pm
If your using v7 then your ver. 6 xml file in VertualDJ root folder would have to be backed up, now in v8 you have a folder that is called "folders" that contain this information, but you should always back up VirtualDJ root folder with all sub folders when doing any major update of music, hardware or configurations...
Good Luck...
