Topic: V8 MIC Effects
Hey guys. Quick question, can effects be routed to the mic output in V8, If yes, please explain?
In 7 i did it by way of the third deck trick..Thanks
geposted Wed 12 Nov 14 @ 8:43 am
Judging by the no response guess it can't be done ... What was i thinking.
There is master FX but I'll guess that isn't what you want,
It appears it's either been dropped or over looked, which is a pity as a bit of reverb sounds good on live mic's, maybe if you can preamp the mic and make it a line in... I'm not sure I don't do mic work.
Yes you have to use the 3rd deck trick as Echo Papa explains here - https://www.youtube.com/watch?v=tdceYcq4P2Q
Appreciate the response... That would be a very useful feature...
