I have 2 of those, with djm2000nexus mixer they are awesome. It is not difficult to create your own mappers especially in vdj8
geposted Tue 28 Apr 15 @ 3:47 pm
Hi Stephane, Hi Atomix Team,
Now that traktor 2.8 + Serato has HD support for XDJ 1000, do you plan to add support for this controller too ?
Looking at it before purchasing :)
Thanks for your feedback, if any provided !
Regards
Yan-x (still alive he he)
Regards
geposted Thu 07 May 15 @ 5:14 pm
Hello Yan-x
there is an answer on this topic :
http://fr.virtualdj.com/forums/200452/Hardware_Technical_Support/Pioneer_xdj-1000_mapping.html
geposted Fri 08 May 15 @ 4:23 am
Thanks for the pointer Lilian, already saw the MIDI mapper but of course i'm watching for HID implementation.
Stephane answered me it was in progress, so I hope this will be an HID implementation, not only a MIDI one.
geposted Fri 08 May 15 @ 4:48 am
We have requested all the necessary information from Pioneer. Once we get those, we may need a couple of testers to verify functionality. We will let u know when this time comes.
geposted Fri 08 May 15 @ 10:04 am
I have two of these and believe me you don't have to carry a router. All I have done is linked the two decks together then used rekkordbox to analyse my files. Export the files to a external drive. Activate USB on deck one then activate the link on deck two and job done. As for cues and loops and much more it's all on the screen i front of you including album artwork. A very responsive piece of kit. as for connecting to virtual Dj it's just a case of connecting them to the usb port. I have had them connected to virtual Dj although I am still working on the mapping features.
geposted Sat 27 Jun 15 @ 10:03 am
seems the XDJ1000 is now officially supported by VDJ8 :
https://virtualdj.com/wiki/VirtualDJ8%20Controllers.html
Will have to plug mine to check that
geposted Sat 27 Jun 15 @ 5:00 pm
It's a awesome screen very responsive indeed. As for your tracks I have 2 Hard drives 500gb I've set both drives to FAT 32 both drives are fully readable from each side and searching for tracks is as simple as ABC you can edit all your cues and loops for each track using the rekordbox and all these when saved work flawlessly on the decks or within VDJ . Giving you more time to add more flare to your mix. They work flawless with or without software.
geposted Thu 03 Sep 15 @ 12:41 am
