Is there somewhere I can find out what is being updated when I get the Update available pop up message when opening up the program? If not I think there should be. It could be very helpful if for example something went wrong software wise and I needed to fault find.
geposted Fri 14 Nov 14 @ 6:34 pm
hi,
when you see the pop up update, press the "change log" and you can read it, or check on the > wiki &manual , on virtualdj history there are all the description builds for VDJ8
best regards
best regards
geposted Fri 14 Nov 14 @ 7:12 pm
Thanks GK
geposted Fri 14 Nov 14 @ 7:20 pm
