The history within VDJ 8 is off by 2 hours. That is when VDJ8 is open.
When you check the history folder from VDJ documents, the time is correct.
Example one tune is played at 10:30 PM;
When you are in the program and check history, it appears as 8:30.
When you go to the VDJ documents history folder, it appears correctly [10:30]
Any ideas??
Any ideas??
geposted Mon 17 Nov 14 @ 2:59 pm
