I've got a simple question that I haven't been able to figure out the solution to. The Virtual DJ software does not allow me to move the tracks in the browser up or down the playlist. They are fixed in rank of either title name, key, bpm etc. and one would like to be able to move a song under another if one plan to have them next to each other in a set right? SO hope someones got a fix for this, thanks in advance. Cheers!
geposted Mon 24 Nov 14 @ 4:06 am
Which VDJ Version and which Buildt-Version of this,do you use ?
Do you mean the Sideplaylist,what i have green coloured and rounded?
When Yes,In my VDJ 8 Pro Infinity Buildt 2048.868 it works,to move the Tracks up and down in ranking.
greatings,Dirk
greatings,Dirk
geposted Mon 24 Nov 14 @ 10:35 am
Or use this feature in Vdj-8 copy a folder add songs and take song out.If using Vdj-7 send them to the auto mix side add and take songs out but DON't turn on Auto mix just save and Name new folder it will be in the playlist
geposted Mon 24 Nov 14 @ 10:49 am
