Forum: VirtualDJ Skins
Topic: [NEW] JUST OLD - Page: 12
not sure which panels you need to control with the NV but here is some useful info..
If some panels inside a skin have the same group="groupname" then you can use the action.. skin_panelgroup 'groupname' +1 to cycle through the panels of this group.
If the panels of the skin dont have a group (e.g. they are visible depending an action/query) then either you need to know which query/action the skin uses or use something like .. skin_panel 'panelname1' on ? skin_panel 'panelname2' on : skin_panel 'panelname3' on
I am sure Zanard will help you more than me. He knows his skin code much better ;)
geposted Tue 23 Jun 15 @ 8:53 pm
thanks Dad...can you check the skins xml though? (or I'll pm you it Lol ) I suspect that these are not "grouped" but also he used the terms "mixer1" ,"mixer2","mixer3","mixer4",and "video" and "video2". but in the text part he uses the actual name of pannels as:
"wave/effect/loop", "vu-meter", "EQ", "scratch", "video" and "Big video/fx" but I see no group set?
geposted Tue 23 Jun 15 @ 9:12 pm
Dj Dad="f the panels of the skin dont have a group (e.g. they are visible depending an action/query) then either you need to know which query/action the skin uses or use something like .. skin_panel 'panelname1' on ? skin_panel 'panelname2' on : skin_panel 'panelname3' on"....
Okay I see what your saying...a swap code similar to a deck swap code.but if we use this ...will it overwrite the native "panel" code (you first example already coded in the native NV code,I know..) making it use less for the original vdj8 skin? or we can implement both,I know but how is that added?
geposted Wed 24 Jun 15 @ 6:36 pm
I did start to make Groups (by finding the code on the original vdj 8 xml then coping it to the Oldschool xml,then opening with the old skin creator and remap,slick huh?) but this is taking too much time,and given me a headache Lol ...so maybe the second choice its better?
geposted Wed 24 Jun 15 @ 6:45 pm
Updated yet Oh master?...
geposted Thu 02 Jul 15 @ 8:18 pm
zanardPRO InfinityMember since 2003
Sent now update 1.5.
geposted Sat 04 Jul 15 @ 3:57 am
but no panel code? :(
geposted Fri 17 Jul 15 @ 4:47 pm
Ok I'm thinking about a new update v.2.
geposted Sat 03 Oct 15 @ 3:14 pm
Nice Zanard!
geposted Sat 03 Oct 15 @ 9:04 pm
Video update:
[youtube]keBzi8xMKOs?rel=0&showinfo=0" frameborder="0" allowfullscreen="1" ></iframe>[/youtube]
geposted Sat 03 Oct 15 @ 10:02 pm
nice Zanard! but what about my request?
geposted Sun 04 Oct 15 @ 12:17 am
Many changes have been made in this release 2:
[youtube]2nohPACGJqY?rel=0" frameborder="0" allowfullscreen ="1"></iframe>[/youtube]
Thanks,
Zanard.
geposted Wed 07 Oct 15 @ 9:46 pm
that is great zanard.about my request...I allready posted the code for the numark in this thread.now if panels work with the numark NV which many vdj users own then I think this has to be done.I dont see why it works with the original vdj skin and some others but not with this skin?
geposted Wed 07 Oct 15 @ 11:20 pm
Will be 3 types of browsers:
Classic
Big
Window
[youtube]s8zBfoTIwvw" frameborder="0" allowfullscreen="1"></iframe>[/youtube]
geposted Mon 19 Oct 15 @ 8:38 pm
Hello friend I downloaded today 3.11.2015 this great tool, but there are not all updates, where is last version please ?? Thank you......
geposted Tue 03 Nov 15 @ 6:08 pm
Because version 2 is not yet ready.
It will still take a while ...
geposted Thu 05 Nov 15 @ 6:37 pm
OK Thank you for info....
geposted Mon 09 Nov 15 @ 6:00 pm
Update:
[youtube]RlWJS4CiVfc" frameborder="0" allowfullscreen></iframe>[/youtube]
geposted Sat 14 May 16 @ 8:21 pm
leneerPRO InfinityModeratorMember since 2014
Very cool:)
geposted Sun 15 May 16 @ 3:02 am
geposted Sun 15 May 16 @ 5:48 pm
91%
