Using Asus G53J with Numark DJio trying to get VDJ8 & Spotify to play. When VDJ8 is on the sound from Spotify is distorted. When off it sounds fine. What am I missing in set-up? Thanks in advance.
geposted Tue 02 Dec 14 @ 10:44 am
What do you mean "on", just open, or are you trying to play a song in both, at the same time?
geposted Wed 03 Dec 14 @ 2:27 pm
Are you using Windows 7 or 8 ?
Here you can't use 2 different sound-outputs (f.e. VDJ=Numark ASIO, Spotify=Numark WDM doesn't work).
If they use the same (f.e. both Numark WDM), then it should work.
geposted Thu 04 Dec 14 @ 2:57 am
Yes "on" meaning open. I'm using windows 7. I will double check my config. Thanks for your help.
geposted Thu 04 Dec 14 @ 6:41 am
Are you trying to play Spotify through VDJ? How so?
geposted Thu 04 Dec 14 @ 7:57 am
No I understand that's not possible.
geposted Thu 04 Dec 14 @ 11:57 am
still no luck getting clean sound from any program running while vdj8 is open using numark djio...any more suggestions? Thanks
geposted Thu 04 Dec 14 @ 4:27 pm
Config/options/audio/exclusiveaudioaccess, what is it set at?
geposted Thu 04 Dec 14 @ 5:40 pm
it's set to "no"
geposted Thu 04 Dec 14 @ 5:57 pm
What does the DJIO say about two programs sharing the soundcard?
geposted Thu 04 Dec 14 @ 6:17 pm
Re read the manual it doesn't say anything about outputting from the laptop, 2 programs into the DJIO.
geposted Fri 05 Dec 14 @ 1:04 pm
Assuming you're using ASIO, it's perfectly normal for the audio interface to only allow one program access. That's the way ASIO works.
geposted Fri 05 Dec 14 @ 1:09 pm
