Topic: Adjusting cue points
There must be a faster way to adjust cue points with my DAC3. The manual says you can edit in the editor or right click to delete the cue point and reset.
In v7.x, if cue point 1 were pressed to play from there then paused, I could use the jog wheel to precisely adjust where I want cue 1 to now be and set it by pressing cue.
I'd prefer that setup for v8 if possible, but even some other equally fast way of adjusting would be nice. Am I missing it?
geposted Wed 03 Dec 14 @ 4:46 pm
how about utilizing snap to beat in the POI Editor?
Please re-read my post.
This script deletes cues
delete_cue X
add that to your mapping somewhere.
That is helpful, I'll give it a try. Thank you.
Just gave it ago. Works beautifly, thank you again.
