Can someone tell me if it is possible to use the same music files and hard drive for both VDJ and Serato DJ? Basically, is there any conflict if I take the same hard drive I use for Virtual and used it with Serato DJ? I am a VDJ user at heart but on occasion, installed systems at some venues I play would be easier to manage if I just ran Serato. Would there be any conflict with databases, cue points, etc. Thanks.
geposted Sun 07 Dec 14 @ 4:56 pm
Shouldn't be, they're separate databases, as long as the tracks stay in the location (you move the track path with either software and the other will lose it)
*Side note* VDJ will read serato cues and set the the V8 cues as a clone if you want it to.
geposted Sun 07 Dec 14 @ 5:13 pm
How?
geposted Mon 08 Dec 14 @ 6:39 pm
getCueFromTags set to always and re-analyse the track
geposted Tue 09 Dec 14 @ 11:25 am
