Topic: File Info
I just set up Virtual DJ 7 Pro on a second laptop. I copied my files over. I have no song plays, cue points, tag changes, it's as if I'm starting over. When I select Most Plays, none of my most plays are there. Am I missing something?
Thank you for any help.
geposted Mon 08 Dec 14 @ 6:57 pm
Not one person has had this happen to them and learn how to solve this problem?
Besides your media files you will also have to copy your database.
And your files must be on the same location on second computer as on first.
Your database is an xml file named "database.xml" inside Documents\VirtualDj folder
On my old laptop with Windows 7, the folder is My Music. My new machine with Windows 8 the folder is Music. I can't change it. This is frustrating.
What happens if you move your music on "the old machine", to a new folder, on "the old machine". Use the same name on "the new machine", and move. I have never used My music, for my pro stuff.
So is switching ;aptops is it best to keep all music on the external hard drive? That way it can be used for both?
Sounds good to me.
