For years, I've used the MixLab skin with VDJ7. While I see there is a version for 8, what I don't like is the way you now have to toggle between automix and sidelist. I use both of these lists at the same time. My side list is my "now playing" list and my automix is my "next set" list. In 8, there's no way to view both at the same time and/or drag songs back and forth between them.
Does anyone know of a skin that's been created that will show both at the same time? Or, even better, is there a way w/in 8 that you can separate them like they were in previous versions?
Thanks in advance for your input.
geposted Fri 12 Dec 14 @ 10:40 am
In V8, go to options, tick advanced and set "showHorizontalSideList" to yes.
Restart the software and you will get the sidelist at the bottom of the browser like V7
Keith
Keith
geposted Fri 12 Dec 14 @ 11:03 am
Perfect. Thank you!
geposted Fri 12 Dec 14 @ 12:14 pm
