I'm looking for something like milkdrop or sonique that you could add in a logo and is also beat synced, is there anything available for vdj 7 or 8?
geposted Thu 25 Dec 14 @ 2:56 pm
choose a exisiting and editable sampler or create one.
Open it with the sampler editor. You can edit the size and position in the preview window.
Set it to loop and sync log. Should work fine.
geposted Fri 26 Dec 14 @ 5:26 am
what is the sampler editor, im kind of confused
geposted Fri 26 Dec 14 @ 8:14 pm
Look here, on page 72.
geposted Sat 27 Dec 14 @ 12:38 am
It does like the name says... you can edit samples with it :-)
geposted Sat 27 Dec 14 @ 9:47 am
i forgot to say im using vdj 7 yet sorry, milkdrop has been doing a pretty good job, its alot of work to put together a bunch of vj loops
geposted Mon 29 Dec 14 @ 10:32 pm
so... this changes a lot... i do not think you are able to do what you want within V7...
but according to your first post.... avaliable for V8 ... yes....
geposted Tue 30 Dec 14 @ 7:19 am
