Hi i selected a skin that does not have a config window and i am stuck with the skin and i can,t change it please help
geposted Mon 29 Dec 14 @ 12:15 pm
Close VDJ
Open Skinfolder and delete the specific skin ....
Relaunch VDJ ( VDJ will use default Skin then )
geposted Mon 29 Dec 14 @ 12:29 pm
You could also create a keyboard shortcut which opens config.
Which skin is this? I would expect that all approved skins would have it.
geposted Mon 29 Dec 14 @ 1:16 pm
Thanks for the help got problem solved deleting skin
geposted Mon 29 Dec 14 @ 2:47 pm
I had this issue as well with the Titanium skin...worked great in 7, but in 8 it has no config option to change skin.
geposted Mon 09 Jan 17 @ 10:07 pm
I know this thread is old, but did you read the second post of this thread?
geposted Mon 09 Jan 17 @ 11:01 pm
