Hey guys i been mapping this buttont to do this
effect 'Loop Out' active & effect 'Loop Out' slider 1 25% & effect_button 'Loop Out' 1 on
when i press the button it activates the effect and it sets the slider at 25% but it never activates the effect button on or off what am i doing wrong im using vdj8
Also what is the script to map the slicer pads thank you
geposted Mon 05 Jan 15 @ 12:09 pm
Slicer pads
effect_button 'slicer' 1 etc
I can't see much wrong with the loop out script but try this
effect_active 'Loop Out' & effect_slider 'Loop Out' 1 25% & effect_button 'Loop Out' 1
geposted Mon 05 Jan 15 @ 3:22 pm
Hey I tried and the effect button did not respond it only activates the effect and the slider but not the effect button 1 it has to be a glitch from vdj8
geposted Tue 06 Jan 15 @ 8:31 am
I forgot to mention if I map effect_button 'Loo Out' 1 by it self it does the function but not when its mapped with other scripts
geposted Tue 06 Jan 15 @ 8:34 am
I have been a dj for the past 6 years and i have not encounter any problem with this amazing dj software.
The only thing i want to know about the software is HOW DO I SET MY OWN KEYS FOR THE SOFTWARE
2. I want to know how to add samplers to your old samplers in virtual 8
MY NAME IS REGINALD QWESI POPULARLY KNOWN AS DJ NORMAL
geposted Tue 06 Jan 15 @ 11:12 am
hi.
no command to map (Virtual dj 7) the following options - for EFFECT- echodoppler I want to put a button on controler this choice '' BEAT '' and options
'' DECK 1 '' - '' DECK 2 '' which is below the ACTIVA
http://s27.postimg.org/o44156137/IMG_20150124_143140.jpg
geposted Fri 06 Feb 15 @ 11:27 am
