Hello All,
Having a real difficult time trying to figure out if there is a way to fade the djay Pro master volume on Mac with a single command/keystroke?
I know we can pause the track, but is there any way to simply fade the master volume with a key command in one touch?
I ask as it is an important part of our music operations at an upcoming event to be able to quickly fade the master volume in djay with one button/command/keystroke/movement/etc.
Any information or assistance to this regard would be greatly appreciated.
Thanks,
Mark
Thanks,
Mark
geposted Mon 12 Jan 15 @ 5:11 pm
Maybe, why not ask on their forum instead of here.
http://help.algoriddim.com/
geposted Mon 12 Jan 15 @ 6:11 pm
Firstly, I did.
Second, no need to be pretentious.
geposted Tue 13 Jan 15 @ 8:48 am
Did you receive an answer ?
Hard for us to say cause this is the VirtualDJ Forum.
If you whish i can move your post in the VDJ mac forum. Perhaps not the perfect place but at least a bit closer to the subject.. ;-)
geposted Tue 13 Jan 15 @ 8:52 am
As above, you would really need to go to the software vendors support. There's nothing pretentious about suggesting that.
