The latest build 2126.906 has this Browser_scroll 'top' and browser_scroll 'bottom' actions added, , now even though it seems obvious how to use it - for the life of me I can't get it to work how I think it should work. Anyone made use of this yet, if so how do you use it.
geposted Tue 13 Jan 15 @ 6:53 pm
wild guess it's for a horizontal split browser/side list
geposted Tue 13 Jan 15 @ 7:28 pm
After reading your message I tried it. Works for me.
Assigning browser_scroll 'top' to a custom button, when the browser scroll bar is anywhere other than at the top, pressing the button brings it to the top.
geposted Wed 14 Jan 15 @ 4:15 am
As Groovin explained allready, it moves the song pointer to the top or bottom of the list visible on the browser.
Quite usefull if you use big lists (Virtual Folders, Playlists, Monitored Folders, e.t.c.) and you wnat to use your mouse as less as possible... ;)
It's the same as pressing "Home" or "End" button on your keyboard when the browser has focus. Only that it can be assigned on controller buttons!!! ;)
geposted Wed 14 Jan 15 @ 6:06 am
