Hello Everyone,
I DJ traditional Greek music, and I have some non stop medleys that are split into single tracks. When I play in winamp, it goes smooth from one track to the next, but when I try to get it into VirtualDj (Load 6 songs in playlist, click Start Automix and select Back-To-Back for AutoMix Type), there is a slight delay when switching songs and it throws the transition off. I am trying to get all my split track medleys converted into one song. Any ideas would be greatly appreciated.
Thanks
Thanks
geposted Tue 13 Jan 15 @ 9:34 pm
If they came from a CD, you could rip as one track with "smartripper", it's free. You could record as one track. Have you tried any other options in automix, to see if you get better results? There is probably a way with the automix editor, I just don't know how to use it.
geposted Tue 13 Jan 15 @ 11:08 pm
Thansk for the response.. Ive tried all options, nothing is workng:(. Where do I get automix editor from?
geposted Sat 17 Jan 15 @ 10:10 am
Have you read the manual? Say, page 76 or so?
geposted Sat 17 Jan 15 @ 10:35 am
Hi Vassili,
I would record them all together in VDJ one time manually.
best wishes
ray
Hi Vassili,
best wishes
ray
geposted Sat 17 Jan 15 @ 11:19 am
All options? Did you try recording the old fashion way, analog? If you record digitally, the track id will also record. You should be able to record through analog cables to a tape/DAC/CD/DVD recorder. Have you tried smartripper? I have not used it in years, but I remember being able to rip multiple tracks as one.
geposted Sun 18 Jan 15 @ 12:12 am
