Topic: DDj SZ Mutiple Effects
Hey i was want to be able to have 6 effects available for each deck by pressing the FX assign buttons like it is stated in the SZ manual for VDJ8. However when I try, it doesn't work that way ie. if I play deck 1 and select FX2 assign and press an effect in FX2 unit the button's LED will turn on for that button in both FX2 and FX1 units but will only control the knob in FX1 unit. If someone could help it will be greatly appreciated. Heres the text from the manual.
The Left FX section (FX1) controls by default the effects of the Left selected software deck
(1 or 3) and the Right FX section (FX2) controls by default the effects of the Right selected
software deck (2 or 4) respectively. Use the FX ASSIGN (11) buttons to assign a different
software deck to each one of the FX1 and FX2
geposted Thu 22 Jan 15 @ 1:11 am
You cant really have 6 effect slots on a single deck with the default mapping. Only 1 FX unit (1 or 2) can be assigned to a single deck.
It doesnt prevent this though, but If both FX units assigned to the same deck, then both FX units will control slots 1 to 3
To get 6 effect slots is of course possible, but it would require deep custom mapping and a special skin of course to show 6 effect slots per deck.
