Topic: Changing the function of the cue button
Hi everyone,
Do you guys ever modify the function of your cue button? I switched over to the ddj sb, and I would really like to be able to jump back to a hot cue point and loop at the same time. Currently, I have to jump back using one pad setting, pause, then open the looper and loop from there. I would really like to loop on the fly by pressing the cue button and the auto loop at the same time.
Then I thought about maybe changing my cue button to jump to the last hot cue I set beforehand instead of what it does currently. Do you guys have any ideas for a work around? Any tips on moding the cue button would be awesome, thanks!
geposted Fri 23 Jan 15 @ 2:33 pm
turning the cue button into a shift type button would be one way of doing it
Press cue+hot_cue X =
cue script: toggle 'hcLoop' while_pressed
hot cue X script : var 'hcLoop' ? hot_cue X & loop : hot_cue X
