I have been using Virtual DJ Pro Basic for a couple of years for small parties, with no controller just on my laptop. I would like to purchase a controller, but there are so many and not sure what would be the best for my situation. Small budget, $250. Not sure what I need. I currently have a Behringer Powered mixer when I use Passive speaker system and have a Behringer Xenyx when I plug into an existing system using their speakers. Not sure if that is relevant but just in case. Welcome your suggestions.
geposted Sat 24 Jan 15 @ 9:07 am
Please have a look here
http://www.digitaldjtips.com/dj-controllers-guide-2015/
there are tons of controllers that could be recomnmended.
First of all you need to focus to what your piorities and essnetial features of a controller are.
Then check out if there is a dealer near you where you can touch and feel some controllers ( very important to me for example)
Of course you can use your mixer but VirtualDJ is a Midi Software ... so maybe a midi controller can possibly be a replacement for exiting one
geposted Sat 24 Jan 15 @ 9:12 am
Your budget and your current list of gear is not as important to your question as your goals. To give you a proper recommendation those reading your question should also know what you plan to do with a controller. Are you a club DJ? Wedding DJ? Bedroom DJ? You get the drift -- what do you plan to do with a controller?
geposted Sat 24 Jan 15 @ 3:12 pm
