hello
I have a question for the dev team on tools / software used to create / encode mapper (definition file / mapper file) of the new integrated controller has as in virtual dj?
Thanks in advance.
Thanks in advance.
geposted Sun 25 Jan 15 @ 9:32 am
geposted Sun 25 Jan 15 @ 11:07 am
What are the tools and or software used by the dev team to define the midi notes (definition / Mapper) of the new controller that it adds in virtual dj?
I imagine that it should not also use a simple XML editor for the Mapper and the miditrace style software to set the midi notes , the colours of the LEDs etc... ???
geposted Mon 26 Jan 15 @ 4:11 am
You can try this one
https://virtualdj.com/addons/12994/VDJ_MIDI_Controll_Definer.html
geposted Mon 26 Jan 15 @ 5:00 am
MidiOX is one of the most common tools: http://www.midiox.com/
Greets, Heiko
Greets, Heiko
geposted Mon 26 Jan 15 @ 5:49 am
thanks
geposted Tue 27 Jan 15 @ 6:26 am
