Hmmm. I'll have to experiment but I believe it's possible...
geposted Sat 23 May 15 @ 5:45 am
1. this sort of restricted search has been aked for already, if you could do this you would be the man!
2. back to the beat phraser, I like to have my CBG on the 1, 'cos it avoids train crashes, long story. I need to see where the sw has placed the 1 ... I have so many songs that are all wrong & have to correct them all before i fade away. So i need a visual 123412341234 and thought that maybe you could put it in the middle ring here ....
and here's the big one, I'd like the first beat to be at 3 O'clock, and I hope this won't become another direction thing ... lol
geposted Sat 23 May 15 @ 2:29 pm
I stole this from Bob 😜 but could we get this on the iPad verison and possibly the skin as well,
I do have some of my samples color coded and plan on using the iPad version for the effects, loops, samples, blah,blah and have the max browser on my laptop.
geposted Tue 26 May 15 @ 10:20 pm
I used this skin this past weekend and it was perfect. The only thing that I found that needs adjusting is the dropdown arrow targets are still too small and instead of dropping the menu, it activates the effect. (Backspinning at the wrong time doesn't sound good!)
I also suspect the the middle panel for just the mixer (without scratch waves) is still a placeholder. (Nothing appears other than a blank panel.)
geposted Tue 26 May 15 @ 10:25 pm
The Central Panel offers 4 views at this point (1 is incomplete and visible by my mistake :P)
So definately not an empty placeholder
Edit:
Aaah. Yes.
The "Full mixer" is not complete yet and it should not be visible as an option yet (my mistake)
It's 50% implemented for 2 decks, but 0% for 4 decks...
Edit:
Aaah. Yes.
geposted Wed 27 May 15 @ 12:26 am
I'll try to tweak sampler pads view more
geposted Wed 27 May 15 @ 12:27 am
Don't get me wrong if it's already ready I'll take what you got now 😜
geposted Wed 27 May 15 @ 12:34 am
The skin allready has sampler pads
But they don't behave like this.
So I'll try to tweak them.
However it's possible to fire samples from the pads
geposted Wed 27 May 15 @ 2:52 am
I found a bug with the FX.
Steps to produce:
1. Select Single FX and Echo
2. Switch to MultiFx
3. Switch back to Single FX
Result:
There is only one Knob for controlling the Echo and it doesnt react to midi-Commands anymore.
Edit:
If you switch between Single and MultiFx with Clicks in the Skin all works fine, I switched with my controller, only then the problem happens.
But all in all the Skin is awesome, just what I needed.
Keep up the good work!
Steps to produce:
Result:
Edit:
geposted Fri 29 May 15 @ 4:14 am
Found the bug!
It wasn't the skin, its a bug in the mapping of the DDJ-SX2 for the Shift-Key:
it is: set '$shift' 1 while_pressed & set '$shift' 1 while_pressed
but should be: set '$shift' 1 while_pressed
geposted Fri 29 May 15 @ 7:16 am
TrueJoshua wrote :
Found the bug!
No, it should be:
set 'shift' 1 while_pressed & set '$shift' 1 while_pressed
I will fix the mapper! :)
geposted Fri 29 May 15 @ 7:18 am
George is the man! :-)
geposted Fri 29 May 15 @ 7:38 am
@Phantom,
Any screen shots of the iPad companion??
geposted Thu 04 Jun 15 @ 11:40 am
Soon! I guess by now you know what's coming up! ;)
geposted Thu 04 Jun 15 @ 3:23 pm
Haha I had no clue when I posted this 😂😂
Can't wait to get home an see what's crackin!!
geposted Thu 04 Jun 15 @ 3:39 pm
POLL time!!!
A:
or
B:
Edit:
For those who wonder what's this all about:
A:
or
B:
Edit:
geposted Mon 15 Jun 15 @ 10:11 am
"A" - The markers should be behind.
geposted Mon 15 Jun 15 @ 11:23 am
A
geposted Mon 15 Jun 15 @ 11:47 am
I think your best option is to provide both.
If you only pick one, someone will complain that they want the other!
geposted Mon 15 Jun 15 @ 11:55 am
Either is fine for me, but I suppose A (behind) is better as it doesn't obscure.
geposted Mon 15 Jun 15 @ 12:23 pm
