Looks great!
geposted Mon 23 Nov 15 @ 3:16 pm
PhantomDeejay wrote :
That's not a ZIP file. That's the installation file.
If you have the skin installed then you should go on Documents/VirtualDj/Skins folder and there you should locate a file named "SilverSleek2.zip"
Okay so I got the right file, edited the image with several different programs, saved the file as a PNG back in the original spot and rezipped the file. When I try to reopen the skin, it says "Impossible to open skin, Skin variation not found."
geposted Fri 11 Dec 15 @ 3:48 pm
Your modified PNG file should have the same name as it was before. Generally speaking the files inside the zip should have the same names as they did before, otherwise VirtualDj will fail to load the correct file(s)
geposted Mon 14 Dec 15 @ 2:35 am
I did just that. When I rezip the file, I'm assuming it must also have to carry the same name as before. Although I did that, Virtual DJ still tells me it is unable to open the skin.
geposted Thu 17 Dec 15 @ 1:52 am
hello, I downloaded the skin but how do I set ut up... using vd8 w ddjsx2
geposted Mon 04 Jan 16 @ 2:10 am
Can someone remind me which section of the xml deals with volume faders? I have them working for decks 1 and 2 but not 3 and 4 for some reason. Thanks.
geposted Wed 06 Jan 16 @ 4:56 pm
I would like to see a battery status in the next update if this is possible George!
geposted Tue 12 Jan 16 @ 7:35 pm
Is there an indicator that display what deck is currently playing. If not, can that be play of your next update?
geposted Wed 13 Jan 16 @ 6:16 pm
I don't understand what you mean...
There are A LOT of elements that indicate if a deck is playing or not. The most obvious been the jogwheel!
If you are asking to see which deck is "on air" then there's a "MASTERDECK" indicator inside the screens of the decks. It's a white "M" glyph
That's the closest you can get as on which deck is "the one plying on air"
geposted Wed 13 Jan 16 @ 6:22 pm
Ok... Thanks. I see what you are talking about. But I'm use two decks and when I use the TAB button. It's going to deck 3 and 4.
geposted Sun 17 Jan 16 @ 3:24 am
switch to the 2 deck version if you don't use 3 and 4 :-)
geposted Sun 17 Jan 16 @ 12:24 pm
It is set to 2 deck. But if you use the tab key it would still go to deck 3 and 4.
geposted Tue 19 Jan 16 @ 10:03 pm
aah sorry didnt realize that
geposted Tue 19 Jan 16 @ 10:07 pm
Probably it's because the skin has only one XML file (which sets nbdecks=4).
If you don't ever use 4 decks then you could change nbdecks to = 2 and the problem should go.
geposted Tue 19 Jan 16 @ 10:20 pm
Just a teaser of the forthcoming update...
Or maybe two:
geposted Wed 20 Jan 16 @ 1:47 am
Is it safe to assume the bottom picture is one of the remote ;-)
geposted Wed 20 Jan 16 @ 3:13 am
I see at least a Freestyler logo and colored CUE pads... I'm in ;)
geposted Wed 20 Jan 16 @ 10:12 am
Oooh... Look at that!!!!
geposted Thu 21 Jan 16 @ 2:58 am
Swap decks?
geposted Thu 21 Jan 16 @ 8:12 am
Don't like being teased! Can't wait... How long??? - Just a hint..
geposted Fri 22 Jan 16 @ 10:35 pm
