Hey guys I need help when I use the effect loop out for vdj8 it activates the effect but when you load a song on the deck were the effect was used it makes the software to crash. It only happens when you use it on skin vd8 4 decks mode and if I use a different skin it does not crash please help. im Using windows pc and the effect is loop out from sbdj for vdj8 also im using the lates update from vdj8
geposted Thu 05 Feb 15 @ 8:58 pm
Might get a better response if you post in vdj8 bug report forum...
geposted Thu 05 Feb 15 @ 9:15 pm
Please don't crosspost; I've moved your report to the plugins forum (since it's a plugin issue) and replied there.
geposted Fri 06 Feb 15 @ 6:01 am
