I'm currrently working on custom mappings for my MixTrack Pro, DJ2GO and LDP8 for 4 deck mixing with default VDJ 4 deck skin. Muddling through nicely, thanks.
I have come across something that I can not figure out. I'd like to have the video preview act as the audio preview does. When I load a video to deck 3 I'd like for the video preview pane to automatically switch to deck 3 just as the audio does for cuing.
I'd also like for the "cue" buttons for each deck to not only change the audio but the video being previewed, just as above. So I would need two functions to work with one button push. Don't know if that is possible.
Thanks in advance,
Tim
Thanks in advance,
Tim
geposted Mon 09 Feb 15 @ 10:22 am
My Norwegian friend tells me this is probably not possible.
Thanks for all the responses, I'm completely under-whelmed. ;)
geposted Mon 09 Feb 15 @ 3:15 pm
Indeed its not possible. My suggestion would be to use a custom 4 decks skin which has preview windows for all 4 decks and not just for the left-right ones.
geposted Mon 09 Feb 15 @ 3:35 pm
Thanks Daddio, I'll start looking now.
geposted Mon 09 Feb 15 @ 3:41 pm
Hi Djdad,
While at it, I have been using your custom Pioneer DDJ-SX skin in 2 deck video mode for my SX2. I had modified it to include the left and right gain knobs under the VUmeters (shortened them in half to fit). My question is: how do I make the master video output the same size as the deck video without changing the screen x-y size (and without going to 4-decks)? The decks and master screens have the same dimensions but the video source = 'master' output is smaller than the video source = 'deck'. Thanks.
Ed S.
Ed S.
geposted Mon 09 Feb 15 @ 3:52 pm
