Any recommendations on some good VST effects that are compatiable with VDJ8 free or paid
geposted Tue 10 Feb 15 @ 1:32 am
Paid for:
Turnado (more awesome than a monkey in a tuxedo made out of bacon)
Effectrix (sequenced multiFX)
For free:
Loudmax (A must)
TAL Filter 2 (mousey but the best drawn line filter anywhere)
TAL Flanger (TAL rule)
DVS Neon Gate (A pretty clean and effective gate)
Bionic Supa delay (the best single effect VST I've seen)
SupaTrigga (random re-arranging mashupness)
Bouncer (KVR challenge 07 entry, trippy druggy disappearing down the plug hole)
For free:
Loudmax (A must)
geposted Tue 10 Feb 15 @ 7:59 am
Free VST Effekte Sites:
http://www.vstwarehouse.com/p/e-f-f-e-c-t-s.html
http://www.vst4free.com/index.php?m=VSTfx
http://music.tutsplus.com/articles/over-90-free-vst-effects-plugins--audio-3834
http://www.pluginboutique.com/effects
http://audioengines.de/category/kostenlos-2/vst-plugins-kostenlos/vst-effekte-kostenlos/
http://www.myvst.com/vst-effects
http://kunz.corrupt.ch/products/tal-vocoder
Have Test some VST Effects with VDJ 8 Pro Infinity that works with this,but have at the Moment onyl write in German Speak,
think later i will translate it and write in English too.
Will test later and on by on more of the VST Effects that works with VDJ 8
You find it on my VDJ Homepage Blog:
https://virtualdj.com/homepage/vlnjacki/blogs/5202/VDJ_8_Pro_Infinity_und_Free_VST_Effekte_sowie_Demos_zu_Kauf_VST_Effekt_Plugins.html
greatings,Dirk
greatings,Dirk
geposted Tue 10 Feb 15 @ 9:51 am
Locodog, where's the point in Loudmax if VirtualDJ 8 already has it's own limiter? What does it improve?
How do you even map VST like Bionic Supa delay?
geposted Sun 12 Apr 15 @ 7:12 pm
Loudmax, try it, then ask questions, if you have any.
Bionic supa delay, map it just like any other VST, use a VST host to get the numbers for the dials
geposted Sun 12 Apr 15 @ 8:00 pm
This effects works only in windows?
geposted Mon 13 Apr 15 @ 12:23 am
I dunno, I've only got a windows machine, don't macs us Audio Units?
geposted Mon 13 Apr 15 @ 12:38 am
looking for anyone using a dubstep working vst... I need to learn this to mash.
geposted Tue 25 Aug 15 @ 6:28 pm
Whats the best setting for LoudMax please.
Thanks in advance
Thanks in advance
geposted Sat 20 Aug 16 @ 5:16 am
I have it ONINIT on master with the dials at 90% 100% but it's up to you and your ears to figure what works best for you
geposted Sat 20 Aug 16 @ 10:56 am
What is that like -3 and 0 ?
geposted Sat 20 Aug 16 @ 1:28 pm
Yeah sumat like that.
geposted Sat 20 Aug 16 @ 1:32 pm
Just a follow up to this (despite it being an old post) to confirm that VDJ8 Mac will use VST plugins too, as long as they are Mac versions obviously.
geposted Sat 20 Aug 16 @ 2:30 pm
Got any examples??
Everytime I try to install one on my Mac (yes the Mac version) I get the"this plugin is not compatible" message.
geposted Sat 20 Aug 16 @ 5:50 pm
If you want to set LoudMax to activate every time at startup, in the controller settings in Virtual DJ8, in the Keyboard mapper,
type ONINIT. Then type the string:
deck 1 effect "loudmax" active & deck 2 effect "loudmax" active & deck 3 effect "loudmax" active & deck 4 effect "loudmax" active
My settings are:
Threash -9db
Output -1db
This works with and without my controller. It's a great tool.
My settings are:
Threash -9db
Output -1db
geposted Fri 26 Aug 16 @ 1:14 am
As the "Threash" slides to the left you hear that increase volume. So instead of using the master volume knob to increase volume you move the "Tresh" slider on the loudmax? Is it the same result?
geposted Thu 01 Sep 16 @ 2:04 pm
Bad idea it you move it to far you will lose dynamic range and compress your music too much all it will cause listener fatigue
I would set thresh to a few points below average peak and other slider to -0.5
geposted Thu 01 Sep 16 @ 4:45 pm
Also I would recommend running it as a master fx instead of on each deck unless you have external mixer setup
geposted Thu 01 Sep 16 @ 4:48 pm
How do I get Glitch to work on a Mac???
Heres what Ive done,
Mac
After opening the ZIP in Finder, you should see the following items:
* Glitch2.component
* Glitch2.vst
* Glitch2_Presets
Copy the "Glitch2.component" file into the following location:
Macintosh HD > Library > Audio > Plug-Ins > Components
Copy the "Glitch2.vst" file into the following location:
Macintosh HD > Library > Audio > Plug-Ins > VST
Copy the entire "Glitch2_Presets" folder to a common location that can be
easily accessed, such as your Documents folder.
Yet nothing shows up in VDJ.
Mac
* Glitch2.component
* Glitch2.vst
* Glitch2_Presets
geposted Fri 02 Sep 16 @ 3:27 am
Glitch2 on pc was a none starter, (didn't load presets, only useful for random or on the fly arrangements.
effectrix (more or less the same) however worked ok
geposted Fri 02 Sep 16 @ 4:10 am
