im only able to get Decks 1 & 2 to mix.
i want 4 ideally.. not at the same time ( although that would nice )
but at least to be able to select 2 of the 4 to mix ..and be able to jump around.
doable?? thanks!
doable?? thanks!
geposted Wed 11 Feb 15 @ 7:08 pm
Yes, completely do-able.
It's even possible to use more than 2 decks video output at once.
geposted Wed 11 Feb 15 @ 7:53 pm
Please share..How?
geposted Tue 03 Mar 15 @ 2:28 pm
Well with the using 2 and jumping around is done by left/right deck selection (or overriden by left/right video).
Since the display of multiple videos is done during a transition, it requires a multi-deck transition, which is supported by the SDK of v8. As yet none have actually been released - the actual practical applications seem rather limited to me.
geposted Tue 03 Mar 15 @ 2:32 pm
Sounds like a 'no' to me Scott.
I've tried but that has been during the pre-release of 8. I have never been so frustrated in my life and gave up on 8 completely.
I'd be willing to give it a chance though if 4 deck video mixing where indeed possible.
geposted Mon 30 Mar 15 @ 1:17 am
4 deck video mixing is possible. What exactly is the hang up?
geposted Mon 30 Mar 15 @ 9:04 am
I'm on VDJ 7 right now so I have not tried to do this since the release of vdj 8.
Mixing VIDEO on all 4 decks and having control over what video was on the main output when needed.
As I remember, controlling that was a bit of a task when I tried it. The reason I even read this post was out of curiosity as to whether the issue had been resolved.
So...you are saying now that it can be done?
geposted Wed 01 Apr 15 @ 9:43 am
I know this thread is getting stale, but I wondered if anyone has come up with a way to select which of the 4 videos (or mash of the 4) you'd see?
geposted Thu 08 Sep 16 @ 5:45 am
Yes, I released some multi-deck transitions that allow you to use as many video decks as you like.
https://virtualdj.com/plugins/?addonid=80282
https://virtualdj.com/plugins/?addonid=80296
When using them you can ignore the video crossfader as that only works for 2 decks. These transitions use the volume level to determine what should be displayed.
If you only want to display/mix 2 decks, then you can use normal transitions and set the left/right video decks to be any deck you like. You can also use the script command over_video to override the video output with that of any deck.
So in short, you can mix video from any 2 decks available with normal transitions, or you can mix videos from more than 2 decks with specially designed ones :)
geposted Thu 08 Sep 16 @ 7:36 am
Much appreciated!
geposted Thu 08 Sep 16 @ 1:00 pm
