I'm trying to figure out how to run a mono signal out of my VMS 4.1. I'm using VDJ 8.
I want to use the XLR out not the headphone jack.
When I go to advanced config and use the mono settings I get mono out but the volume for decks 1 and 2 work off of the deck 1 slider and I'm not able to preview in the headphones.
I need to run mono at a club that only has a single XLR input for their system.
geposted Thu 12 Feb 15 @ 4:17 pm
in audio config set the channels to mono
or get something like this to connect the vms to -> https://www.google.com/shopping/product/13623489935813350440?q=convert+stereo+to+mono+xlr&safe=off&biw=1920&bih=939&bav=on.2,or.r_cp.r_qf.&bvm=bv.85970519,d.eXY&tch=1&ech=1&psi=5zPdVMnPHofCggT694KYAw.1423782891423.3&prds=paur:ClkAsKraX5QmK5vkDwxBpvmes_rDwFs-amtHQQ1BSJdeqnQkkP2br9rB0aMyYrO3gSSkiNC1NJ9gJSeN4fZ4Klhdt78L4V7u9VoPS2wcFeQnKC5uB_fCnR7M8RIZAFPVH71UujdrngVnnOMySdc27TVrJnboAw&ei=7DPdVKrSNcS6ggTj6IE4&ved=0CI4EEKYrMAE
geposted Thu 12 Feb 15 @ 5:13 pm
I'm wanting to see if anyone knows how to setup the software to make mono work using my XLR output. The box you referred to would require me to use the RCA outputs. If I have no other options then I will.
geposted Thu 12 Feb 15 @ 7:02 pm
can you please post a screenshot of your current Audio setting ?
geposted Fri 13 Feb 15 @ 1:21 am
Have you tried to change the audio routing in the ASIO drivers panel?
geposted Fri 13 Feb 15 @ 4:38 am
Audio is set this way Deck 1 ADJ ASIO Out 1 (mono)
Deck 2 ADJ ASIO Out 2 ( Mono)
I also tried both decks set to Out 1 (Mono) at the same time
geposted Fri 13 Feb 15 @ 11:34 am
Also did the same setup with decks 2 and 3.
Once again I get mono out but I can not control the volume on each deck all volume gets controlled off of one deck.
geposted Fri 13 Feb 15 @ 11:44 am
The vms4 has an external mixer which is probably why you having troubles ...
Another hardware option pure xlr
http://www.mcmelectronics.com/product/555-15155?scode=GS401&catargetid=530004080000290616&cadevice=m&gclid=CjwKEAiA3vamBRDJ1Lfwt5Pckw4SJAAdhnk202h0C7J4mOPQp6LaOxS0zrTOVfiws8-0J83FVxCBEhoCxaXw_wcB
geposted Fri 13 Feb 15 @ 12:59 pm
Yeah I may have to go that route. Thanx wickedmix
geposted Fri 13 Feb 15 @ 1:38 pm
You could try to set the VMS to pure Midi mode and check again with your mono routing.
Have a look at the manual and search for pre-EQ mode or post-EQ mode.
geposted Sat 14 Feb 15 @ 4:09 am
Have not tried that yet. Could you explain why you think that may work?
Thank you
Thank you
geposted Sat 14 Feb 15 @ 9:54 am
