Hello guys and Gals, my name is Robbie and I have been a Virtual DJ user for some time now and this is my firs post. :)
Got a question, just started doing Karaoke on my own with my own gear. I have purchased some karaoke files, some are normal and some have vocals that are split tracks (I think), vocals on left channel and music on the right. How can I play just the music without vocals in stereo in Virtual DJ 8. I run everything out of a Pioneer DDJ-SB controller and HDMI out of my laptop out to a 32" tv. I run my sound into a Behringer Xenyx 2442 board using RCA to two 1/4 plugs on my 15/16 channel. I like doing it this way and am the most comfortable doing it this way. I know I can run it out mono on just the right channel and daisy chain from one speaker to the other but then I would be loosing stereo and just feel it sounds better in stereo.
Thank you for any help.
Robbie
Robbie
geposted Sat 21 Feb 15 @ 6:23 pm
When using the split tracks you want to use this pluggin
https://virtualdj.com/addons/14832/SBDJ_StereoChannel.html
This will give you dual mono
Or if you really insist on stereo, You'll have to make an FX chain, with the mentioned plugin first & this free VST after.
http://www.voxengo.com/product/stereotouch/
(voxengo are very good VSTs)
geposted Sat 21 Feb 15 @ 8:47 pm
Awesome, thank you so much for the reply. I will install the plugin and test it.
geposted Sun 22 Feb 15 @ 7:54 pm
