Forum: Old versions
Topic: Radius 1000 & virtual dj 8
jtats33PRO InfinityMember since 2014
hello
just bought the radius 1000 system but having problems with jog and pitch slider not working at all also on one cd player some leds work but other one none was wondering if anyone can help with this
thank you
geposted Mon 23 Feb 15 @ 9:59 am
I suppose those are used units since they are discontinued long time ago.
Please try with Miditrace or MIDIOX (or other similar application) and see if the pitch slider and the Jog properly send MIDI notes. (Could be faulty units)
geposted Mon 23 Feb 15 @ 12:30 pm
actually they where new in box from planet dj but thanks will try
geposted Mon 23 Feb 15 @ 3:34 pm
Thanks for help all I needed to do was reset radius to default settings but lights only work on one of the radius
geposted Fri 27 Feb 15 @ 12:47 pm
