Hello,
I've been having an issue with VDJ8 not auto updating itself to the newest released build (while already logged in). Is there a way to manually make it check for updates?
Also, when VDJ8 is open on my laptop (Windows 7) I can still see my windows taskbar at the bottom whereas the older version 7 would take up the whole screen. How can I set VDJ8 to be full screen? Thanks in advance.
geposted Tue 24 Feb 15 @ 10:28 pm
To set VDJ to Fullscreen just click on the green + at the upper right corner again.
If you want beta versions you could set "getBetaBuilds" in Options to yes.
You can set it in your user profile too.
https://virtualdj.com/users/edit.html
geposted Wed 25 Feb 15 @ 5:40 am
I'm looking to update to the latest tested build's - not beta. It didn't update the last time I was connected to the internet and logged in. Is there a way to manually run the update or "check for updates" ?
geposted Wed 25 Feb 15 @ 3:00 pm
Also, is there a way to disable the remembering of the last music folder you used? Every time I start up vdj it's always set to the last folder I was in.
geposted Wed 25 Feb 15 @ 3:02 pm
The latest public build is always available here:
https://virtualdj.com/download/
There is an option for the lastSavedFolder. But it seems you can't disable it.
geposted Thu 26 Feb 15 @ 7:19 am
