I have a dell and no mouse scroll. Is there a way to zoom in.. and out .. the pad idea sounds good but it doesnt zoom when i go up or down..
geposted Tue 24 Feb 15 @ 11:41 pm
You can resize the horizontal scrolling bar using your mouse (no need to have a scrolling one), which actually zooms in/out the waveform.
geposted Wed 25 Feb 15 @ 1:13 am
Also, scrolling using your touch pad should work fine as well.
(Depending on your settings, might be two-finger-scroll, or using the right side of the touch pad)
geposted Wed 25 Feb 15 @ 2:09 am
silly as it `sounded , thanks .. i had no idea.
geposted Wed 25 Feb 15 @ 1:13 pm
