Hi, guys.
Is it possible to write a script for a button which starts a song at a cue 1 and finishes playing a song automatically at a cue 2? I don't prefer samples instead because recording a new sample takes time and it's hard to mix them.
geposted Thu 05 Mar 15 @ 10:01 am
You could have a poi at the same position as cue 2
action ="stop"
Then you just press hotcue 1 and it does what you want.
action ="stop"
geposted Thu 05 Mar 15 @ 10:32 am
what you mean ''poi''?
geposted Thu 05 Mar 15 @ 10:49 am
It doesn't seem 'hotcue' helps because it has just starting position but not ending position at a next cue. If I use it with 'stop', it would be 2 actions and I need 1.
geposted Thu 05 Mar 15 @ 10:57 am
VDJ 8 User Guide page 61.
geposted Thu 05 Mar 15 @ 10:59 am
I'm using VDJ 7 and there is no editor.
geposted Thu 05 Mar 15 @ 11:05 am
No them you can't. not with VDJ, use audacity to re-record the desired part.
geposted Thu 05 Mar 15 @ 11:11 am
