Topic: Uploadng a song. The spectrum does not show entirely.
Hi you all,
I am uploading songs to the decks and unfortunately I can't see the whole spectrum until the song has been fully played.
Any ideas to improve my situation?
Thanks,
Tony
geposted Sat 07 Mar 15 @ 1:33 am
Probably you are trying to load tracks that exceed the default Maximum Pre-Load length (default value is around 10mins if not mistaken)
Every track that exceeds this value will "stream", so it wont be analyzed/wont be loaded into memory.
This setting cant be changed from Config (change to a larger value), but for LE versions this is not available.
