hello ,
i have virtual dj 7 LE which came along with mixtrack ii numark. problem is i can only sort out my tracks with key tab which shows them as letters and #s, however i want to sort them by harmonic keys which are numbers and a's or b's is there any possible addon to do so? i can't find it between the options i have for the tabs such as length bpm key...
thanks
thanks
geposted Thu 12 Mar 15 @ 10:36 am
Look in the VDJ Browser with rightclick and activate key (numeric)
have it green rounded in the Screenshot,but waiste not does this goes in VDJ 7 LE Versions.
greetings,Dirk
greetings,Dirk
geposted Thu 12 Mar 15 @ 1:15 pm
thanks for the help, but the problem is i dont have the number key in between the menu once you right click as you highlited, maybe perhaps its because i have the LE edition
thanks for the help anyway
geposted Tue 17 Mar 15 @ 9:14 am
Just drag it where you want it
geposted Tue 17 Mar 15 @ 4:12 pm
It seems as there is no way to search by the "Harmonic". You have to search by "Key". If I want a 5A, type in c-m and all 5As will come up, 12A, type in c#f, etc.
9B is a G Major. There is no way to search by this. If you type in G-M or g-m, 6A will come up.
I'm using Virtual DJ 8, pro by the way.
Any ideas?
Any ideas?
geposted Sun 14 Jun 15 @ 6:05 pm
The compatible folder in the LHS explorer window will give you all the songs you have in key (approx). It will do + or -1, and A or B, but not jumps of +7, or energy boosts of +2.
Is that not enough?
Is that not enough?
geposted Sun 14 Jun 15 @ 6:38 pm
Ron, I use this all the time. I need to know the jumps. If I'm playing a 7B and want to go into a 9B, I have no way of listing the 9Bs. Like I said, it's the only key that can't be searched by the letters.
geposted Sun 14 Jun 15 @ 6:43 pm
This list I made will help a lot of people. Example: if you want a 1A, type g#
1A g#
1B B-M
2A d#
2B F#
3A a#m
3B C#
4A f-m
4B G#
5A c-m
5B D#
6A g-m
6B A#
7A d-m
7B F-M
8A a-m
8B C-M
9A e-m
9B The ONLY key I can't come up with. G Major, should be G-M but 6A comes up in search.
10A b-m
10B D-M
11A F#M
11B A-M
12A c#m
12B E-M
1A g#
1B B-M
2A d#
2B F#
3A a#m
3B C#
4A f-m
4B G#
5A c-m
5B D#
6A g-m
6B A#
7A d-m
7B F-M
8A a-m
8B C-M
9A e-m
10A b-m
10B D-M
11A F#M
11B A-M
12A c#m
12B E-M
geposted Sun 14 Jun 15 @ 6:57 pm
We should be able to construct a similar folder to the compatibility one using filter folders which includes +2.
Left click the third button down on LHS (filter folders). Create a new one named harmonic mixing or something.
In the available fields select key difference, then all we need do is define the operator, maybe -1 to +2.
A much easier method.
Except I can't get it to work at the moment...hm.
I've got a key diff of 2 coming up on 3a giving a range of 1a to 5a.
We can do better than that!
geposted Sun 14 Jun 15 @ 7:23 pm
Can't you just drag the BPM column to the #1 position to the LEFT, or wherever you want it. Then click on top of the column to index in ascending or descending order.
I usually index my BPMs in ascending order, THEN index my KEY column. It groups all my songs in BPM order for each KEY.
Then use the Camelot Wheel to figure out the jumps.
geposted Mon 15 Jun 15 @ 3:34 am
That works if all your songs are in one folder. However I use sub folders, and it only lists the particular folder selected.
Why do you use the camelot wheel?
List the numeric keys, and an energy boost is +2. I would assume since +7 is compatible, then +8 is yet another energy boost?
geposted Mon 15 Jun 15 @ 4:35 am
I use KEY because I grew up with that. I haven't taken the time to learn the "numerical" way. I edited the BlackSheep skin and have KEY loaded by default now on all 4 decks. Plus I increased the font size for easier viewing.
I have a JPG of the Camelot Wheel in the corner of my screen. But there seems to be a lot of unusable "spokes".
Version 8 seems to capture a wider assortment of keys. But I'll still do the calculation in my head. Like a "G" would be paired with an "E Minor" minus the Minor to make "E". Or the other way to a B-Flat Minor less the Minor for a "B-Flat".
I really enjoy mixing in KEY because of the way music blends together in a way that makes sense. Glad I took time to learn it.
geposted Mon 15 Jun 15 @ 6:12 am
