Topic: Laptop Set Up VDJ Broadcast
Hi Guys I'm off to Australia on Monday and hope to be able to broadcast my radio show using VDJ broadcast whilst out there.
I am setting my laptop up and wanted to ask for advice on the correct audio settings please. I am using VDJ8 on a Win7 os. My Soundcard is a Realtek High Definition Audio and I have a USB mic Anua Mic CM 900.
In VDJ audio settings, I have the Master source set as Realtek High Definition Audio (WASAPI) on Channels 1&2. The bit that's confusing me is the USB mic. Do I set it's source up as a mic or record (or something else?) and should the channels be 1&2 as well.
Hope that makes sense and would be grateful for any advice you can offer me.
geposted Fri 13 Mar 15 @ 1:10 pm
When I broadcast I set mic as mic using ASIO should be the same the way you are doing it
Good luck
Thanks Wicked, it's not giving me ASIO as an option do I need to install anything driver wise for this, if you know?
no no just set as mic under WASAPI sorry for the confusion
ok thanks very much - no worries on the confusion not hard to do that to me lately !
