Hi everyone
I have a question about the Hot Cues. How can I configure them, that when i press one of them, they play just as long as i press the button for the hotcue and when i stop pressing the button the track stops too, doesn't matter if the track is already playing or not?
geposted Sat 14 Mar 15 @ 6:02 am
There is no setting for that mode, a hot cue will always keep the track playing if it is already.
You would have to create a custom script or control to do that using the default cue commands instead.
geposted Sat 14 Mar 15 @ 6:20 am
Thanks, i thought so...
What about remix points in tracks?
In the user guide of VDJ8 is written the following:
How i can see this aviable remix points in the sampler?
in the song the are marked as visible and marker only
geposted Sun 15 Mar 15 @ 10:26 am
DJPitchBlack wrote :
Hi everyone
Try this in place of your Hotcue mappings
setting HotcueMode "stutter" & pause & hot_cue X
geposted Sun 15 Mar 15 @ 10:58 am
I already answered you in the german forum.
There is an option for the hotcue behaviour called "hotCueMode".
Make sure the "show advanced checkbox" is checked.
EDIT: This option is available since beta 2171.
geposted Mon 16 Mar 15 @ 5:05 am
Yes, i didn't have activated the beta updates, so i didn't get this option. Now I have it. Thanks a lot`!!
geposted Mon 16 Mar 15 @ 7:13 am
