DJdad did a great job updating the controller page for ver 8, here.
geposted Tue 17 Mar 15 @ 3:05 pm
Ok so I want the numark quad controller Does it just plug in and couple itself with the software? Or do I have to "map" it..I'm not good with computers I need a controller that is dedicated to the software
geposted Tue 17 Mar 15 @ 3:35 pm
All controllers on that page are plug and play .... but of course you can change from the "default" mapping if you want to.
geposted Tue 17 Mar 15 @ 3:41 pm
You also have a thread opened on that subject. Please don't double post.
geposted Tue 17 Mar 15 @ 3:46 pm
Thank you I apologize for double posting
geposted Tue 17 Mar 15 @ 4:12 pm
geposted Wed 18 Mar 15 @ 6:24 am
Incredible work Dj Dad!!
I just wanted to post here to help out with a couple of errors that I found and thought it best to post publicly in case others pick it up too and you end up with a barrage of the same messages. Feel free to delete my post once errors are addressed. : )
Novation product Twitch is incorrectly spelt without the 't'.
Numark Products that have the 'i' prefix are inconsistent. I believe that the 'i' is supposed to stay in lower case despite being first letter. So iCDX is correct currently but iDJ3 and iDJ LIVE II need to change to lower case 'i'
In the title 'MIDI and HID Controllers supported in VirtualDJ 8' should the word 'controller' be capitalised?
Hope that helps.
BISH
Hope that helps.
BISH
geposted Mon 23 Mar 15 @ 8:23 pm
Thanks for your comments. Will fix the typos.
Note that the page is still under construction, so yes, the images will be clickable when done and will open subpages with all the info, links, description, manuals etc for each one of them (or at least for the most popular and recent ones)... something like this https://virtualdj.com/wiki/Suported%20Controllers%20-%20PIONEER%20DDJ-SZ.html
geposted Mon 23 Mar 15 @ 9:08 pm
