I find the number of 12 a very small amount of samples possible to use in VDJ7.
Is there a way to extend the number of playable samples through MIDI?
geposted Thu 19 Mar 15 @ 3:00 am
12 is the most you can have at one time with V7 but you can have banks of 12
With script, or using this tool
https://virtualdj.com/addons/16084/Sampler48.html
V8 however allows banks of (a guess) 48? 64?
geposted Thu 19 Mar 15 @ 3:08 am
Great and fast replies as always! Highly appreciated!
This is something for me. Thanks!¨
EDIT:
I downloaded the application but could not find info IF this four bank system is compatible with VDJscript so I can really change bank from controller?
EDIT:
geposted Thu 19 Mar 15 @ 3:12 am
Try using the learn button in mapping,
you can load samples via script, take a look at V7 verbs page, I think it's something like
sampler X load "M:\file.mp3"
Where X is the sample slot
geposted Thu 19 Mar 15 @ 7:54 am
VirtualDJ 8 allows for a maximum of 64 Samples per bank with an infinite number of banks.
geposted Thu 19 Mar 15 @ 8:32 am
Aha! Aha! This means I do not need the "sampler48" dll then?
geposted Thu 19 Mar 15 @ 8:58 am
It's probably better using the dll as it makes changing samples within banks easier.
geposted Thu 19 Mar 15 @ 9:14 am
