Topic: Video as "background" for karaoke
I know there is an option to set a background image to be displayed between songs under the karaoke list, but is there a way to use video instead? Or would this work under the "background music" option?
geposted Tue 24 Mar 15 @ 2:37 pm
KaraokeBackgroundMusic allows you to select any folder you want, including a video folder.
Ah, thanks. I selecting a video as the background image, but it didn't play the audio.
I will try setting a folder as the "background music" and see what happens.
Put some videos into automix, and select automix and see what happens.
Hi. How can i use background images for karaoke while playing Instead of the blue screens ? VDJ 7 OR 8.
Txs
GK.
