Hello
What is "get_rotation_cue" that was added in BUILD 2191
I can't seem to find in information on it...
Best regards
Klaus Mogensen
Best regards
Klaus Mogensen
geposted Tue 07 Apr 15 @ 3:54 am
The action returns the position of the CUE marker on the jogwheel (values 0.0 to 1.0)
So if you use this on a controller with Leds around the jog or on a visual on the skin, it will show you on which position the jog will stop if you press the CUE button.
So if pressing the CUe button the Jog returns to 9 o clock position, the action returns 0.75
geposted Tue 07 Apr 15 @ 5:57 am
Ok. Thank you :)
geposted Tue 07 Apr 15 @ 5:58 am
