I'm using VDJ8 and everything is smooth except when I use the Loop Out, no matter how I adjust it, it cuts abruptly at the end. How do I achieve a smooth fade out?
geposted Thu 09 Apr 15 @ 6:42 pm
Are you using the V8 effect
https://virtualdj.com/plugins/?addonid=80111
You might want to look at rampStopTime too, drop it to zero.
geposted Thu 09 Apr 15 @ 6:54 pm
I downloaded it. It's still chopping of the last beat. Frustrating.
geposted Thu 09 Apr 15 @ 7:08 pm
I have already reported a similar problem with the Vloop Out V.8, i also sent a message to SBDJ...
geposted Thu 09 Apr 15 @ 7:12 pm
"no matter how I adjust it, it cuts abruptly"
You understand that it has two parameters which require seperate knobs. One varies the loop size whilst the other varies the number of loops before complete fade out? It's very good, and one that the phantomdeejay uses. Another of his effects is flanjet which is even better!
geposted Fri 10 Apr 15 @ 6:56 am
Hello, can anyone help with this? Vdj 7 backspin does not work during loop, when using it in Virtual dj 8. I use Vdj7 backspin alongside loop ( ie. loop 1/4, 0/2 or 1) to give the scratching effect you would have, when using external turntables. Renamed Vdj 7 backspin works fine in Vdj8, but unfortunately, V7 backspin doesn't initiate, if you're in loop 2, 1 , 1/2 or 1/4. Big ups in advance.
geposted Sun 12 Apr 15 @ 1:54 pm
1 post was enough, Don't cross post, & no it's not possible.
geposted Sun 12 Apr 15 @ 2:22 pm
Alright thanks, and sorry for the posting. Will watch it next time.
geposted Sun 12 Apr 15 @ 4:52 pm
hey guys can some1 help me with something. i am trying to adjust the looproll effect on vdj7 but i am having trouble with the mapping process. i want to make it so that every click of my second slider, it loops 1/8th of a beat.
geposted Mon 13 Apr 15 @ 3:25 am
@Locodog; V7 backspin works fine, when the loop is 4, 5 or beyond. Any idea as to why it doesn't work with short loops from 2 and below?
Greetings to everyone.
geposted Mon 13 Apr 15 @ 3:51 am
Dj Akdls it was blocked off from V8 for a reason, perhaps this was the reason.
geposted Mon 13 Apr 15 @ 6:02 am
Sounds to me like the fade option in the loop out plugin GUI isn't enabled.
geposted Mon 13 Apr 15 @ 9:16 am
@Locodog; Alright dude, I think I understand it know. 1000 appreciations and keep rocking.
geposted Tue 14 Apr 15 @ 5:51 pm
