Hi everyone,
i'm currently using MusicBee to sort and edit my music since it supports all kinds of tags and display formats.
I know that VDJ also supports a lot of tags, but i have a little problem:
VirtualDJ has the tag fields User1 and User2 which i would like to use in accompany with MusicBee.
The two fields work fine for VDJ but i can't figure out how to read them in MusicBee, i just can't find them.
MusicBee has so called "Custom Fields" from 01 to 16 by default and i thought the first two would match up with the ID3 tags of User1 & 2 of VDJ, but they don't.
I would really like to use these fields across other software because i need to tag my music with more tags than normally (e.g. Dance-Type).
If someone can help me to use more ID3 tags in VDJ i would appreciate it a lot.
Regards,
Daniel
Regards,
Daniel
geposted Sat 11 Apr 15 @ 6:48 am
user 1 and user 2 do not go to the tags they only go to the VDJ database
see this post for more info -> https://virtualdj.com/forums/193684/PC_Version_Technical_Support/Tag_types_supported.html?search=id3%20wickedmix&page=1.25
geposted Sat 11 Apr 15 @ 8:38 am
Thanks for the information, i was also thinking about that but i didn't test it.
Well then, is there any extension for VDJ to support more tags (ID3v2.2, ID3v2.4) ?
Or is that a feature we have to hope for in the future?
geposted Sat 11 Apr 15 @ 10:12 am
