Is it possible to sync 2 VDJs one on laptop one on PC. Example, on the desktop i make a filter folder and populate it with parameters of my choice, but i want it to also make the change on dj laptop. Right now i use freefilesync to keep my music folder synchronized together. What files and/or folders do i sync together?
geposted Tue 14 Apr 15 @ 9:05 pm
Come gurus i need you right now....do i need to explain more
geposted Wed 15 Apr 15 @ 4:03 pm
best way is to keep music on an external drive and use on both systems and sync the "my documents/virtualdj" folders with some type of syncing app like syncback etc....
if you keep music on the internal drive things become more complicated because u need to maintain identical file structures on both systems so the music database can be synced
geposted Wed 15 Apr 15 @ 4:46 pm
